Displays the hardware serial and version numbers, the software version currently running on the switch, and (if applicable) the software version running on the power controllers.
| detail | Specifies display of platform name. |
| process | Specifies display of all of the processes on the switch. |
| name | Specifies display of a specific process on the switch. |
| images | Specifies the display of installed images. |
| partition | Specifies display of a specific partition (primary or secondary). |
N/A.
For information about the physical location of the serial number on your switch, refer to the section that describes your specific switch model in the hardware documentation.Depending on the model of your switch and the software running on your switch, different version information may appear.
The following command displays the hardware and software versions currently running on the switch:
# show version
Switch : 800992-01-03 2011G-00108 Rev 03 BootROM: 2.2.1.3 IMG: 31.1.0.631
Image : ExtremeXOS version 31.1.0.631 by release-manager
on Tue Sep 1 13:58:24 EDT 2020
BootROM : Default 2.2.1.3 Alternate 2.2.1.3
Diagnostics :
Certified Version : EXOS Linux 4.14.170, Extreme Networks FIPS Object Module 2.0.16a
Build Tools Version : exos-arm64-sdk-3.0.3.1.0
The following example shows SSD-120 device information:
# show version
Slot-1 : 800908-00-01 1847F-10076 Rev 01 IMG: 30.3.0.453
VIM5-4XE-1 : 800910-00-01 1845F-10106 Rev 01
XN-SSD-001-120-1: 800954-00-02 1917F-10030 Rev 02
Image : ExtremeXOS version 30.3.0.453 by release-manager
on Thu Jul 11 11:52:10 EDT 2019
Diagnostics :
Certified Version : EXOS Linux 4.14.123, Extreme Networks FIPS Object Module 2.0.16m
Solid State Storage Device SSD-120 information was added in ExtremeXOS 30.3.
BootROM version for ONIE switches (which do not have a BootROM) appears as "N/A" for compatibility with Chalet in ExtremeXOS 30.4.
BootROM version for both partitions was added in ExtremeXOS 31.1.
